I am using a SIM5360 and works very well for GPS and GSM communications. Now I am using the SPI too: I have the SPI activated (AT+CGFUNC) and configured (I following the SPI application note). But, when I send a command (only been tested with write commands) I have always 3bytes with 0x00 after addres and before the data that I want transmit.
Someone have the SPI communication working fine in a SIM5360 module?
Thank you.
It sounds like padding, since the max. transfer size is 4 bytes. I assume you mean that the receiving side sees 0x000000bb when you send data bb. It may be that you transfer unit is set to 32 bits i.e 4 bytes. You can check with AT+ CSPISETPARA?.
If that's the case, you can try changing it with AT+ CSPISETPARA =8,0,1 which means you'll only send 8 bits when transferring byte-sized data.
|improve this answer|||||
  • \$\begingroup\$ Thanks for your answer, but I have the cspisetparam ok, for 8 bits. I following the application note for SPI communication in SIM5360. I tried with 8, 16 and 32 bits bit I have always the 0x00... this is very strange. I am using the EVB and I have Uart2 disabled and the CP2103 in reset... \$\endgroup\$ – user146886 Apr 23 '17 at 0:21
  • \$\begingroup\$ @user146886 EVB? UART2? CP2103? You need to give better details. \$\endgroup\$ – TisteAndii Apr 23 '17 at 1:29
  • \$\begingroup\$ Maybe you can try messing with the last parameter i.e. packing data from the output buffer. Try AT+ CSPISETPARA =8,0,0 instead. \$\endgroup\$ – TisteAndii Apr 23 '17 at 1:38
