This is a typical PCB from ebay, front and back side:
PCB front and back
The sides are identical, and not mirrored. Which is funny because the A row on the front is the X row on the back.
Is there a logical/practical reason to this, or is it just convenient for the manufacturer to print only one layout instead of mirroring the letters on the other side? I would find it much more useful if the letters were mirrored and could be used to uniquely identify a hole, no matter which side I am looking at the PCB from.
    \$\begingroup\$ I would say it is not a question to manufacturer, but rather to PCB designer - the person or entity producing Gerber files. I agree with @Trevor you need to ensure that flipping board around the same edge you see A on pad at one side and X on the same pad on another side, it is not clear from your picture (and from your explanation). \$\endgroup\$
    – Anonymous
    Commented Apr 22, 2017 at 9:18
  • \$\begingroup\$ The manufacturer hired an inexperienced PCB designer who did not pay attention to this detail. \$\endgroup\$
    – user64167
    Commented Apr 22, 2017 at 16:02
  • \$\begingroup\$ Can you show the whole board btw. \$\endgroup\$
    – Trevor_G
    Commented Apr 22, 2017 at 16:04
6
You got what you paid for. Rock bottom quality at rock bottom prices. It's typical of cost cutting manufacturing.
  • \$\begingroup\$ In what way does producing a PCB in this manner "cut costs"? Is it that much cheaper to duplicate the print on the reverse of each unit rather than having a second, pseudo-mirrored print? \$\endgroup\$ Commented Apr 22, 2017 at 12:16
    \$\begingroup\$ @BoundaryImposition I presume it would be, tooling is one of the larger costs of PCB manufacture - one set of silk screen stencils. Probably even only one set of masks for copper, solder mask and silkscreen. Use the same masks for top and bottom sides. \$\endgroup\$ Commented Apr 22, 2017 at 12:59
  • \$\begingroup\$ @TomCarpenter: I see! \$\endgroup\$ Commented Apr 22, 2017 at 13:05
There's no logic, practical or convenient reason for this. If what you write is true, it is not a typical PCB. It's a flawed PCB; someone made a mistake.
    \$\begingroup\$ Or just stereotypical Chinese engineering. \$\endgroup\$ Commented Apr 22, 2017 at 6:13
  • \$\begingroup\$ It is in fact from China. (Updated my question.) \$\endgroup\$ Commented Apr 22, 2017 at 6:38
    \$\begingroup\$ @SimonA.Eugster It doesn't have to be from China to have a mistake. I once swapped the letters next to a pin header on a board I made. However, I never tried to sell them.. \$\endgroup\$
    – pipe
    Commented Apr 22, 2017 at 14:08
Which side is the "FRONT" ?
Arguably it does not have a front till you put something on it... at which point the labels on the back become meaningless.
Still not too handy though.
    \$\begingroup\$ Not really. Put item a in hole a1 and a3. Now solder a1 and a3 on the back. Item a falls out. Instructions unclear. Because of the mismatched labels. \$\endgroup\$
    – Passerby
    Commented Apr 22, 2017 at 15:43
  • \$\begingroup\$ @Passerby, yes I understand, and agree with you. But figured it was worth a mention. \$\endgroup\$
    – Trevor_G
    Commented Apr 22, 2017 at 16:05
