Your model should look something like this where OA1 is an ideal op-amp...
For D.C. and tying both inputs to ground you can simplify that to.
The voltage dropped across R_4 becomes
\$V_4 = R_{3|4} / I_{b+} = 900/-0.00001 = -0.009V = -9mV\$
Using the worst case \$V_{OS} = -0.01V\$, the voltage on the negative pin of the op-amp becomes:
\$V_- = V_4 + V_{OS} = -0.009 - 0.01 = -0.019V = -19mV\$
The current through \$R_2\$ can now be calculated:
\$I_2 = V_-/R_1 + I_(b-) = -0.019/1000 + 0.00001\$
\$= -0.000019 + 0.00001 = -0.000009 = 9uA\$
The offset output voltage then becomes:
\$ V_out = V_- + R_2 * I_2\$
\$ = -0.019 + 4000 * -0.000009 = -0.019 - 0.036 = -0.055V\$
Maximum offset is therefore \$-55mV\$
NOTE: Solving for \$V_{OS} = +0.01V\$ only yields \$ V_{out} = +45mV\$.
So more accurately this circuit can be expressed as
\$V_{OUT} = 4.5*V_{i2} + 4 * V_{i1} ±(0.045,-0.050)\$
