Hi When calculating the pull up resistor value using the formula R = 50 / d, where d is the number of devices on the bus, is the master considered a bus device?
for e.g. If I have a micro controller master and two slave devices on the bus should this count as a total of 3?
For extra credit: Am I using the right formula? if I use 3 as number of devices this tells me I should use 16k6 pull-ups, which seems high... Ta
    \$\begingroup\$ At what (bit) frequency do you want to run that I2C bus? \$\endgroup\$
    – Telaclavo
    Apr 17, 2012 at 12:12
Three. Electrically the master controls the bus in exactly the same way as the slaves.
I'm not sure where your formula comes from. The spec states that pull-up resistors are to be chosen in function of bus capacitance and speed(page 55):
  • \$\begingroup\$ "function of bus capacitance" - Which would be a related to the number of devices surely? Ta \$\endgroup\$
    – Toby
    Apr 17, 2012 at 12:15
  • \$\begingroup\$ "in function of bus capacitance" and speed. \$\endgroup\$
    – Telaclavo
    Apr 17, 2012 at 12:16
  • \$\begingroup\$ @Telaclavo - Yes, shown in the graphs, but not in the answer. I'll edit it. \$\endgroup\$
    – stevenvh
    Apr 17, 2012 at 12:23
