In my previous question I asked about a simple topology suggestions for regulation of highish currents (around 10A) especially for resistive heating elements in 1...10 Ohm range. I concluded to use a MOSFET controlled via a PWM signal from microcontroller since PWM duty cycle is linear with the power of the heating element (I guess same linearity for the temperature).
And now after I made some readings about the importance of the current being measured, I would like to measure the current through the heating element and send this information back to the microcontroller. So I decided to measure the voltage across it and then divide this to the resistor value (neglecting heating element's tolerance) and have an estimation for the current so forth and so on.
Before soldering this on a perfboard I wanted to have your opinions for the below circuit I modified so far:
And before going in detail here is LTspice simulation plots for the current through heating element, MOSFET's instantaneous power and average power and the final voltage output to the MCU input:
I want to go from left to the right:
The control signal is a 0...5V 490Hz PWM signal from a microcontroller pin.
A 12V 10A SMPS power supply will be used for a max 0...8A PWM current through the element. C4 and C1 are for noise in the supply.
Q1 Q2 are inverting logic. This is because I want MOSFET to saturate when control signal is ON. I could also use a logic MOSFET but I don't know if IRL3903 is a logic MOSFET from the datasheet. I don't know which parameter makes a MOSFET a logic MOSFET. Is that something to do with gate to source voltage being less than 5V? I have no idea so I decided to use this NPN inverter driver to make it usable for any power MOSFET.
In some examples I saw there is a 20k resistor between the gate of the MOSFET and the ground. In simulation I didn't find it necessary but I'm not sure if needed.
And for the measuring part I decided to use an an LM358 in a difference amplifier configuration(I'm not sure in practice it is a good op amp for this application). The voltage across the heating element is too high for the microcontroller and it is not pulled down to the ground because of the voltage drop across the MOSFET. If I shunt it between the source and the ground then I get less current. So I needed a negative gain meaning that 12V to less than 5V. So I obtain a gain of R4/R1=R3/R2=0.33. The reason I didn't use an inverting op amp configuration is I use a single power supply and inverting op amps have low input impedance. And I also didn't use a non-inverting op amp because as I mentioned then I have to shunt the heating element between the source and the ground.
One of my question is the gain I'm aiming is R4/R1=R3/R2=0.33. But the resistors should be matched. What does that mean? Would 1% tolerance resistors be enough for roughly measurements here(since I'm not measuring mV level small voltages)?
And finally I added a 4.7V zener for precaution to the MCU input. (Would it be good to add a 100Ohm 100n lowpass filter right before this?)
I would be glad to have your opinions or any major mistakes with this circuit.
EDIT:
I was suggested not to use a difference amplifier and a single ended op amp config instead together with a mOhm level low resistor. I tried to use a non-inverting config. since I have a single supply.
But I'm getting distorted output if I use a non-inverting configuration.
Here is the modified circuit with LM358:
And the plots for input(non-inverting input/blue plot) and the output of the op amp:
And here is similar issue with another opamp LMC6482:
Basically the gain must be (1 + R3/R7).
But the PWM signal is distorted(like a lowpass filtered pulse) and it doesn't go to ground when the input is zero.
How can I fix this problem?
