I'm trying to find the quality factor of this circuit but I'm not sure how to do it. I know how to find it for a series RLC circuit and completely parallel RLC circuit, but I don't know what to do when the resistor is in series as shown here.
Any help is appreciated!
The voltage source can be assumed to be ideal and therefore have zero internal impedance. So you now have a voltage source in series with 100 KΩ. This can now be replaced with a current source in parallel with 100 KΩ. This is just a Thevenin-Norton transform which many textbooks describe. Now that everything is in parallel, the Q is easy for you to complete for your homework.
I'd take the bandwidth-centric approach to this:
By analysis of the circuit, find the cutoff frequencies.
Then, follow the formula
$$B = f_{cutoff,upper}-f_{cutoff,lower} = \frac{f_{center}}Q\\ Q = \frac{f_{center}}{f_{cutoff,upper}-f_{cutoff,lower}}$$
Personally, I never got that warm with the component-value based approaches to calculating Q; point is that to me, it's a "sharpness" measurement of a resonant circuit, and the "logical" definition of that is the ratio between center frequency and bandwidth.
Generally, I find that "Q factor" is a nice measure, but far too often abused as a simplistic abstraction. For example, the Q factor of this circuit doesn't tell you anything about how the heat-converted power is distributed across frequency.
