Below is a circuit consisting of a capacitor, voltage supply and resistors. There is a switch that lets the capacitor charge and discharge. I have also uploaded the given answers below;
I understand that for:
(i) Tc: you find the thevenin resistance and multiply it by the capacitor value.
(ii) Vc Max: the voltage across the parralel (Rz) resistor.
(iii): I am not sure that he has done there. Has he used the capacitor charge or discharge formula and rearranged it of some sort?
(iv): Not sure what hes done here?
. enter image description here
  • \$\begingroup\$ What is your specific question? \$\endgroup\$
    – The Photon
    Commented Apr 23, 2017 at 15:00
  • \$\begingroup\$ Despite the propaganda, there is nothing simple about charging and discharging capacitors. However that aside, what is your question? \$\endgroup\$
    – Trevor_G
    Commented Apr 23, 2017 at 15:37
  • \$\begingroup\$ Not sure how he has calculated III and IV part of the question \$\endgroup\$
    – Michael
    Commented Apr 23, 2017 at 15:42
  • \$\begingroup\$ Im a bit confused about how he has calculated it in the answers \$\endgroup\$
    – Michael
    Commented Apr 23, 2017 at 15:45
The charging equation look like this:
$$V_C = V_{th}(1 - e^{\frac{-t}{RC}}) $$
Now to solve for the "time"\$(t)\$ we need to rearranged this formula.
First we can divide by \$V_{th}\$
$$\frac{V_C}{V_{th}} = 1 - e^{\frac{-t}{RC}} $$
We subtract 1 from both sides and multiply both sides by -1
$$\frac{V_C}{V_{th}} - 1 = - e^{\frac{-t}{RC}} $$
$$1-\frac{V_C}{V_{th}} = e^{\frac{-t}{RC}} $$
take the ln() of both sides
$$ln(1-\frac{V_C}{V_{th}}) = {\frac{-t}{RC}} $$
Multiply both sides by -RC
$$-RC*ln(1-\frac{V_C}{V_{th}}) = t $$
Swap sides
$$t = -RC*ln(1-\frac{V_C}{V_{th}})$$
\$t_d\$ is a discharge time constant \$t_d = R*C \$
Where \$R\$ is a resistance seen by the capacitor when discharging.
  • \$\begingroup\$ It makes total sense. Tried it with a few other questions and it works like a charm. Cheers \$\endgroup\$
    – Michael
    Commented Apr 23, 2017 at 18:39
