In BJT for working in active region for a common emitter configuration emitter and base should be in forward bias and base and collector should be in reverse bias. But in case of voltage we say that base-collector voltage should be less than 0.4V.enter image description here
But if V(base)-V(collector)=0.1 (suppose) then base-collector junction will be in forward bias that means it will enter into saturation mode. But book says it will remain in active mode. How is it possible?
  • \$\begingroup\$ For one, 0.1V isn't enough to bias any pn junction into conduction, unless you have some really weird semiconductor. \$\endgroup\$
    – Hearth
    Apr 25, 2017 at 12:51
  • \$\begingroup\$ that means i will not get any collector current? \$\endgroup\$
    – Leolime
    Apr 25, 2017 at 12:53
  • \$\begingroup\$ Carefully study the BJT in active mode again, The B-C PN junction will not be in forward mode to allow Ic to flow. So there will be a collector current despite the B-C junction being not forward biased. That is basically the whole point of a BJT in active mode. \$\endgroup\$ Apr 25, 2017 at 12:55
  • \$\begingroup\$ No--it means your base-collector junction is not forward biased. \$\endgroup\$
    – Hearth
  • \$\begingroup\$ then can i say that V(collector)-V(base)>-0.4V? \$\endgroup\$
    – Leolime
    Apr 25, 2017 at 13:00
Here is a bipolar I_V plot; saturation is the far left region; notice all the lines merge in "saturation", not good for linear amplification but good for switches.
Here is the circuit used to produce that plot
