I feel a bit silly asking this..
I have a relay, which has a switch that turns it on/off. Next to the switch I have an indicator light which needs to turn on when the switch is turned on.
I tried putting the LED in parallel (seen below) and in line, but no luck.
(by the way, the 22k resistor is a good value for this LED at this voltage)
