I’m working on a project that involves a STM32 MCU (on the STM32303C-EVAL board to be exact) that has to respond to an external interrupt. I want the reaction to the external interrupt to be as fast as possible. I have modified a standard peripheral library example from the ST web page and the current program simply toggles a LED at each successive rising edge on PE6:
#include "stm32f30x.h"
#include "stm32303c_eval.h"
EXTI_InitTypeDef EXTI_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
static void EXTI9_5_Config(void);
int main(void)
/* Initialize LEDs mounted on STM32303C-EVAL board */
STM_EVAL_LEDInit(LED1);
/* Configure PE6 in interrupt mode */
EXTI9_5_Config();
/* Infinite loop */
while (1)
// Configure PE6 and PD5 in interrupt mode
/* Enable clocks */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOD | RCC_AHBPeriph_GPIOE, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Configure input */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Connect EXTI6 Line to PE6 pin */
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOE, EXTI_PinSource6);
/* Configure Button EXTI line */
EXTI_InitStructure.EXTI_Line = EXTI_Line6;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable and set interrupt to the highest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
The interrupt handler looks like this:
void EXTI9_5_IRQHandler(void)
if((EXTI_GetITStatus(EXTI_Line6) != RESET))
/* Toggle LD1 */
STM_EVAL_LEDToggle(LED1);
/* Clear the EXTI line 6 pending bit */
EXTI_ClearITPendingBit(EXTI_Line6);
In this particular case, the interrupts are created by an external programmable function generator running at 100 Hz. After examining the MCU response on an oscilloscope, I was rather surprised that it takes nearly 1.32 us for the MCU to begin processing the interrupt:
With the MCU running at 72 MHz (I’ve checked the SYSCLK output on the MCO pin beforehand) this amounts to nearly 89 clock cycles. Shouldn’t the MCU response to the interrupt be much faster?
P.S. The code was compiled with IAR Embedded Workbench and optimized for highest speed.
if{}
statement is needed because the interrupt routine does not know what the source of interrupt is. \$\endgroup\$ – Rohat Kılıç Apr 25 '17 at 19:59
