I have a working AT45DB and SST26VF driver I made and successfully implemented it for elm chan's FAT-FS. But as you know a NOR or NAND flash will wear out after 100,000 write cycles, so I have to include wear leveling to increase it "lifetime". Do you know of any open source middleware wear leveling block? I found Spiff, which is a file system with wear leveling included. But I was hoping to use Chan's FS as it is well maintained and quite robust.
  • \$\begingroup\$ FatFS is for SD/MMC cards.. not raw flash \$\endgroup\$
    – hassan789
    Commented Apr 26, 2017 at 5:35
  • \$\begingroup\$ Actually, FAT FS was made for magnetic disks. And we have uCs inside an SD/MMC which would take care of emulating it to be a magnetic disk. This emulation technique is achieved by wear leveling, bad block management, garbage collection etc. So yes it's not for "raw" flash, but in the end an SD is a raw flash with a micro inside it. \$\endgroup\$ Commented Apr 26, 2017 at 9:09
  • \$\begingroup\$ ok, so first you will need to implement FatFs without wear leveling on the raw flash. if you can do that (big if), I would recommend static wear leveling, as its pretty straight forward \$\endgroup\$
    – hassan789
    Commented Apr 27, 2017 at 5:00
  • \$\begingroup\$ also, FatFs in not really that robust, as it doesn't journal... i've used SPIFFS in the past..its ok for non critical stuff \$\endgroup\$
    – hassan789
    Commented Apr 27, 2017 at 5:02
  • \$\begingroup\$ Yes, I got Chan's FS working with my flash drivers. And I implemented an amateur wear leveling which basically just remaps worn out blocks with new spare blocks I had kept aside. But this, as you might have noticed isn't great. And I thought static wear leveling would be harder than dynamic WL. There would be too much book-keeping in case of static, I'm I right? \$\endgroup\$ Commented Apr 28, 2017 at 3:37
If you are using a Dataflash use a flash file system (YAFFS, SPIFFS, NIFFS) or any other. As @hassan789 said, FAT does not journal.
    \$\begingroup\$ It also worth to mention LittleFS \$\endgroup\$
    – desertkun
    Commented Feb 6, 2019 at 20:29
