Hi and thanks in advance
I'm not from the field so please understand. I need a mean to detect a PWM frequency of pc/laptop displays externally. Some led displays use PWM mechanism to produce different brightness levels and I need to detect it for multiple machines. The frequency can get as high as 20Khz
Any clue for such a high frequency sensor?
Thanks
  • \$\begingroup\$ Seems like a PIN diode photodetector would work. \$\endgroup\$ – mkeith Apr 26 '17 at 6:16
Fortunately, 20kHz isn't high frequency. Just about any photodiode should be able to handle 20kHz with no problem, especially if you negative bias the anode to reduce the capacitance and thereby reduce the rise time.
Here's a fairly plain photodiode from Vishay, available for under a dollar from DigiKey: http://www.vishay.com/docs/83471/tefd4300.pdf
The datasheet indicates that under 10 volts of reverse bias, the rise and fall time of the photodiode is on the order of 100ns. That's sufficient to detect oscillations up to 5 MHz, so you should have no problem detecting 20 kHz.
The standard transimpedance amplifier setup probably makes the most sense for your application:
In the above diagram, you might be able to just forego reverse bias altogether and replace V1 with ground (since your frequency is so low) if you don't want the hassle of generating a negative rail. Choice of Rf depends on how much gain you want, playing with this value will change your transimpedance gain (ie: how many volts you get on the output for current from the diode). Cf is optional and is used to prevent ringing - the value assigned here will give a cutoff around 200 kHz (calculated by 1/(2piRfCf)).
For further information on designing with photodiodes, this app note by Microchip is quite handy: http://ww1.microchip.com/downloads/en/AppNotes/01494A.pdf
Finally, OSI has an excellent pamphlet on various photodiode circuits: http://www.osioptoelectronics.com/application-notes/an-photodiode-parameters-characteristics.pdf
    \$\begingroup\$ Ordered and I'll test soon. Thanks and I didn't forget you! \$\endgroup\$ – ifyougetwet May 3 '17 at 12:24
    \$\begingroup\$ Hi, me again. I think making the amplifier myself is too much for at this stage. Do you have any recommendation for a complete module or something that I can just "plug in" Also, any scope recommendation? \$\endgroup\$ – ifyougetwet May 30 '17 at 13:47
