13
I am experimenting with large currents from ultra capacitor discharge.
For example with 500 A (at 2.8 V) you get a very impressive demonstration of the magnetic field of a straight conductor using compass needles or iron chips (compare: http://iopscience.iop.org/article/10.1088/0143-0807/31/1/L03/pdf).
Another example is the Thomson ring experiment http://www.rose-hulman.edu/~moloney/Ph425/0143-0807_33_6_1625JumpingRing.pdf where you may get up to 9000 A for a very short time.
Suppose all voltages used are below 60 V. What do you need to consider about safety in this case?
Here is what I think:
  • Since the voltage is too low, there should be no danger from current through the human body.
  • There might be a danger from sparks and lightening when if there are contact problems.
    • This may be dangerous because of UV light
    • and because of sparks hitting directly the eye
  • Also the there might be heat problems which makes thinks to vaporize which you may inhale
  • A capacitor discharge generates an EMP which may affect pacemakers for example
I am not sure if I mentioned all possible dangers concerning this. My question is:
  • Under which conditions (minimal current, discharge time...) which danger will become relevant
  • What to do to make it safe
  • 5
    \$\begingroup\$ 60V is high enough to be a potential hazard. Even car batteries, at no more than 12V, are to be treated with care, because they can output a lot of energy very quickly into whatever they're connected to. This is the sort of thing that, if you have to ask, you really shouldn't be doing it. \$\endgroup\$ – Hearth Apr 26 '17 at 12:37
  • 6
    \$\begingroup\$ High current can generate very high voltage and substantial energy with just a bit of inductance when switched so you can't ignore that. Burn hazards and possible blindness from molten metal and eye or cancer-causing UV skin damage (you can get a bad 'sunburn' from a low voltage arc). Even a car battery can cause loss of a finger if you accidentally weld it across a conductive ring. Try to find University health and safety guidelines or corporate ones. Some of us have written them. \$\endgroup\$ – Spehro Pefhany Apr 26 '17 at 12:48
    \$\begingroup\$ Don't forget to add "have fire extinguishers at hand" and "buy some insurance" to your safety checklist. \$\endgroup\$ – Enric Blanco Apr 26 '17 at 14:12
  • 5
    \$\begingroup\$ I think Spehro's point is V=L*di/dt. If you have some L and switch the current very rapidly (high di/dt) you can get very large V. So the basic inductance formula quantifies the point nicely. And all cables and wires have some L. \$\endgroup\$ – John D Apr 26 '17 at 14:47
  • 5
    \$\begingroup\$ Things I can think of that aren't in your list, mostly collected from YouTube videos of risk analysis by people who like to blow things up: Accessible fire extinguisher; fire resistant carpeted flooring if you're working with things that may spray molten metal (sounds counter-intuitive but carpet prevents molten bits from bouncing into unnoticed/inaccessible places); never work alone always have a buddy; beware of things that create x-rays; have a remote location where you can cut power from if you need to escape; clear the room of tripping hazards; keep the area clean and tidy. \$\endgroup\$ – Jason C Apr 27 '17 at 4:37
If we consider this model of a high energy switching circuit we can simulate the induced voltage on a nearby conductor. This provides a simple simulation of the type of electromagnetic interference that would be coupled into nearby conductors or electronic devices.
As any switch opens, or you simply tap wires together to briefly conduct that 1,000 amps, when you have 1u (1 micron, 10,000 Angstroms, or 1/25th of a mil) separation of the wires, the 3 volt potential causes an arc.
The 100pF across 1micron separation (3mm by 4mm ---- heavy wire --- contact) will resonant with the 1uH (~~ 1 meter) wire in your high-current path. Fring will be 15MHz. What is the dI/dT of 1,000 amps ringing at 15Mhz?
100,000 MegaAmps/second.
Place a wire 4" from the high current, that wire formed into 4" by 4" loop; expect 2,000 volts across the ends of that 4" loop.
  • \$\begingroup\$ Nice, but I guess that the 200 V will be there only a very short amount of time (how much?). Then the deposited energy will be the relevant parameter. How much will the energy be if I touch the contacts of your 200 V wire? \$\endgroup\$ – Julia Apr 26 '17 at 16:10
    \$\begingroup\$ I had a typo; the dI/dT is 100,000 amps/uSec or 100Billion (10^+11) amps/second; thus Vloop is 2,000 volts; note the Vinduce formula --- if totally accurate --- needs some integration and/or natural_logs. However, for ratios as I used, with Distance and Loop edges approx. the same, there is little error. So expect 2,000 volts. \$\endgroup\$ – analogsystemsrf Apr 26 '17 at 16:19
    \$\begingroup\$ @JRE: As I said, it depends on the time scale and then on the energy. I often touched a demonstration parallel plate capacitor (low energy!) or a whimshurst machine (30 kV), nothing happened (however I calculated the energy content before using it). \$\endgroup\$ – Julia Apr 27 '17 at 5:25
    \$\begingroup\$ The OP wanted to know how to be safe. This answer illustrates the risk. \$\endgroup\$ – analogsystemsrf Apr 27 '17 at 14:08
    \$\begingroup\$ If the ringing frequency is 15MHz, the skin depth (where 63% attenuation occurs) is 17 microns. But at 2,000 volts versus 20 milliVolts (neural potentials), you need 100,000:1 attenuation; at 8.6 dB per skindepth (neper) you need 100dB (100,00:1) / 8.6 dB or 12 skin depths or 200microns. Seems like the scalp tissue will keep the energy out of the neurons. But your mileage may vary on these numbers. \$\endgroup\$ – analogsystemsrf May 3 '17 at 3:51
