The sensor I am investigating is the 1-LM11 by Omega.
I am looking at the specification at there are two metrics which confuse me, the measurement grid A is 1.5mm while measurement grid B is 2.5mm. This really doesn't make much sense intuitively while looking at the picture
enter image description here Dimensions C and D seem slightly more likely with them being 9 and 4.4 respectively. Could someone clarify what the market grid is exactly?
The measurement grid is the actual active part of the sensor, the resistance wire that is used to measure deformation. Your picture might be a bit misleading, as it seems your ratios between dimensions are very different from those in the picture, but that's why they give you numbers--so they don't have to make a separate to-scale image of every product in the line.
