I'm a newbie in EAGLE, so I'll try my best to explain myself.
I need to connect a micro controller (port 19 and 18 in the pic) to two different components (pinhead and usb).
So, for instance, I've proceeded with: right-click --> Name --> USB_DP and I placed a label on the net, but how do I create a functioning connection for ICSP_DAT? In the image ICSP_DAT is showed that way just because I've added a text with layer 95 Names.
EDIT
As suggested, I used label 91 Nets for ICSP_DAT and left USB_DP as wire's name. This solution produces this result using SHOW command on ICSP_DAT's text and selecting wire 19:
Is it ok, or should I use label 91 Nets for both? ERC gives a warning: "Only one pin on net ICSP_DAT" (regarding to the example above).
(I had to re-upload images to stay in the 2-images limit for "low-reputation" users, also I needed to show images to explain myself, I couldn't just comment below)
