I've built a simple adjustable voltage regulator, but running the ERC shows two errors:
The first one claims that PIN1 is not being driven (it's connected to GND through a resistor; the label is connected to a power pin, connecting the label directly without a resistor fixes the error). I can "fix" the warning with a PWR_FLAG.
The other problem is that the LM1117 family parts have a hidden 4 pin hidden below the 2 pin, both marked as "Power output", and this makes the ERC show an error of "ErrType(5): Conflict problem between pins. Severity: error. Pin 4 of U2 is connected to pin 2 of U2".
Is it possible to fix this error?
