I am looking for the exact formulas for the impedance of an electric and magnetic wave in the near field region.
We have some approximates:
Zwe≈ 1 / (ω * ε0 *r)
Zwm≈ (ω * µ0 *r)
where r is the distance, ω is the angular frequency, ε0 vacuum permittivity, µ0 vacuum permeability
However these formulas are only approximations, and I believe the accurate formula involves complex numbers.
I could not find the full formula for this, I was hoping somebody here would know it.
  • \$\begingroup\$ The book Corson and Larrain might have those equations. \$\endgroup\$ – analogsystemsrf Apr 27 '17 at 12:46
  • \$\begingroup\$ @analogsystemsrf if you are talking about "Electromagnetic Fields and Waves - Lorrain and Corson" , I have quickly read through the book, and there are a lot of complex equations there, but most of them are talking about electric charges and electromagnetism is a conductor. I haven't seen anything about waves and wave propagation. I've went to page 263, where it detailed the Characteristic Impedance (ω * µ/ k ) but this is essentially the far field vacuum impedance equation, 376.73 Ohm. I could not find an equation for the near field. \$\endgroup\$ – user138887 Apr 27 '17 at 17:39
  • \$\begingroup\$ I have also looked here dannex.se/theory/3.html , equation 46 and 47, but they are just alternate forms of the equations I provided above. So they are still approximates, and not the precise formula. I am looking for the accurate formula though. \$\endgroup\$ – user138887 Apr 27 '17 at 18:13
I haven't got formulae but I have this picture that may help a little bit: -
Picture taken from here http://incompliancemag.com/article/guide-to-testing-conducted-emissions-based-on-the-methods-in-en-55022-and-en-55011/
|improve this answer|||||
  • \$\begingroup\$ Yes I know about that relationship that is why I asked specifically about the near field. In the far field the equation becomes that of the free space (µ0*c). Also it looks like the relationship is inverted between the magnetic and electric field in the near field. However I think a true formula has to include in some way the wave propagation constant which has an imaginary element in it. \$\endgroup\$ – user138887 Apr 27 '17 at 14:02
I have found a potential good answer:
enter image description here source: http://m.eet.com/media/1140940/19711-figure_2.pdf
A general formula for wave impedance, where we know that the magnetic impedance is essentially the inverse of the electric wave impedance.
To calculate the near field impedance, just use a common definition of the near field like:
r < λ / ( 2* π)
Which was defined by Ott & White, or other definitions depending on the situation: http://m.eet.com/media/1140939/19185-table_1.pdf
Information source: http://www.edn.com/design/communications-networking/4340588/Near-field-or-far-field-
