1.regarding to logic gate concept i have to design the circuit with 4 bits multiple of 3 detector. but when i trying to make logic gate and truth table it seems to me it's wrong so i have no idea how can i do design circuit with 4 bits multiple 3 detector with truth table and circuit shape. 2.what actually detector do in logic gates and what is the affection of that on truth table? enter image description here
  • \$\begingroup\$ Can you explain a bit more what you want? I'm guessing a '4 bits multiple of 3 detector' is a circuit that outputs high when the input is a multiple of 3? \$\endgroup\$
    – Hearth
    Commented Apr 27, 2017 at 11:28
  • \$\begingroup\$ Following @Felthry's question, is this a 'detect the numbers 0, 3, 6, 9, 12, 15' circuit? \$\endgroup\$
    – TonyM
    Commented Apr 27, 2017 at 11:48
  • \$\begingroup\$ This isn't, try with 0011... It gives out 0 \$\endgroup\$
    – Simus994
    Commented Apr 27, 2017 at 11:54
  • \$\begingroup\$ the outputs high when the input is a multiple of 3 \$\endgroup\$ Commented Apr 27, 2017 at 11:59
  • \$\begingroup\$ How are you drawing the truth table? \$\endgroup\$
    – Hearth
    Commented Apr 27, 2017 at 12:03
You first have to write down the truth table, get the logic function f(x1,x2,x3,x4) and minimize (if possible, but I think in this case is not) it with the Karnaugh Maps method. Then you can draw down the circuit using some AND ports (with 4 inputs) and a OR port (with 6 inputs if the f() is not minizable). Let's try.
Edit: I say 6 inputs because you have 6 multiples of 3 in 0-15 range
  • \$\begingroup\$ that was in my mind but how to find out the output in truth table?as you know we write the Kharnaug Maps corresponding to the row which we have 1 as out put.this my main problem i don't know where is 1 in truth table \$\endgroup\$ Commented Apr 27, 2017 at 13:19
  • \$\begingroup\$ If you have 4 inputs you can have 16 binary combination that correspond to 16 numbers, from 0 to 15. Which of those numbers are 3 multiples? 0,3,6,9,12,15. You have to put 1 for all this numbers. And 0 for others obviously... \$\endgroup\$
    – Simus994
    Commented Apr 27, 2017 at 13:33
