I have the following differential amplifier and I would like to find which is the output resistance of this circuit in the cases of differential input and common mode input.I know that the input resistance in the cases of differential input signals is Ridm = 2*rπ and for common mode signals is Ricm = rπ/2 + (β+1)R3.But for output resistance which is the relations?
Also Ι simulate this differential amplifier in Pspice.The results was Rout= 100kΩ when I set a common mode input and Rout= 200kΩ when I set a differential mode input.Hοwever, I can understand the reason for this result and how I can prove through theory.Can anyone help?
