I was just wondering if someone could tell me if I am doing this right, because I don't really have any sample problems but just want to be prepared for anything. If we wanted to find the output voltage of this system could we find:
The gain by Rf/Rs Then multiply Va*Gain?
*It would not be square rather just a 5v source.
So gain would be: 36k/12k or 3; so Va*3 would be the output?
Gain from the positive input is 1 + (R1/R4) = 4.
The voltage at the positive input is R2/(R2+R3) times the input V1.
So the voltage gain from V1 to the output is (1+R1/R4)*R2/(R2+R3) ~= 2.222.
  • \$\begingroup\$ So I ran those numbers and got 2.77 at voltage Va, and then gain would be 4. So output would be ~11.1V, does that sound about right? \$\endgroup\$
    – noreturn
    Apr 27, 2017 at 18:24
  • \$\begingroup\$ 2.222 * 5V is 11.11V, yes. \$\endgroup\$ Apr 27, 2017 at 18:27
No.
What you've drawn there is a non-inverting amplifier.
The amplifier keeps the voltage across R4 equal to Va. The voltage across R1 is 3 times Va, so the total output voltage is 4 times Va.
