I see a lot of Bluetooth adapters OBD-II reading speed, temperature, etc. Does that adapter read from the CAN bus with standard broadcasting?
If read with standard broadcasting from the CAN bus, where can I find this standard table of broadcasting? I need the speed value address.
  • \$\begingroup\$ Speed and temperature are standard PIDs and will be broadcast on the buss regularly not requiring any query. All you have to do is listen. \$\endgroup\$
    – vini_i
    Commented Apr 28, 2017 at 9:55
  • \$\begingroup\$ can make an example of broadcasting ? i use an ArduinoBoard with mcp2515 for sniffing canbus, where i can find a table with all address standard of CANBUS broadcasting? \$\endgroup\$ Commented Apr 28, 2017 at 10:00
The OBD PID for speed is 0x0D. The below link gives all available PID's
https://en.wikipedia.org/wiki/OBD-II_PIDs
