Hey I took apart a joystick and I found some pretty neat parts. I found multiple of these knobs; I think that's what they're called.
Characteristics of Component
  1. Turns
  2. Three wires
**Picture **
picture of component
My question(s)
  1. What is this switch called?
  2. How do I connect it to an LED(Connect it in general)
  1. Potentiometer.
  2. That depends entirely on what you want the circuit to do.
Read up on potentiometers, what they are and how they work. That will tell you how, and if, you connect it to your LED.
  • \$\begingroup\$ Cool I always wanted one of those, can it dem an LED? \$\endgroup\$ Apr 28 '17 at 14:03
  • \$\begingroup\$ Yes. It can also burn a LED out. Read up on LEDs to understand why. Hint: LEDs are current driven, not voltage driven. Now that you know what the component is called, Google is your friend. Happy reading! \$\endgroup\$
    – Dampmaskin
    Apr 28 '17 at 14:04
  • \$\begingroup\$ Lol. You can find "one of those" in any electronic junk or buy for few cents in a store. You can dim a LED with it, but it is not the most efficient way. \$\endgroup\$
    – Eugene Sh.
    Apr 28 '17 at 14:05
  • \$\begingroup\$ I don't think it's quite fair to say for a few cents. It's at least a few dozen cents. \$\endgroup\$
    – Hearth
    Apr 28 '17 at 14:19
  • \$\begingroup\$ Ok cool, thinks for your thoughts. \$\endgroup\$ Apr 28 '17 at 15:40
While I'm not 100% sure since it could be some rudimentary rotery encoder, it's almost certainly a potentiometer. The way you connect it to an led depends on what you want to do.
    \$\begingroup\$ Easy way to tell is that most rotary encoders you can turn continuously, and almost all potentiometers you can only turn through about one full rotation (some more than one, but almost all of them will hit an end stop on their rotation) \$\endgroup\$
    – Hearth
    Apr 28 '17 at 14:23
  • \$\begingroup\$ Ok cool, this one does stop. \$\endgroup\$ Apr 28 '17 at 15:39
