I have an MSP430G2101 and I need to use the Watchdog to trigger an interrupt. The code I am trying to use is the following:
#include <msp430.h>
#include <stdint.h>
unsigned int cycle = 0;
unsigned int pwmred = 1;
void main(void)
WDTCTL = WDT_MDLY_0_5;              // WDT as interval timer (period 0,5 ms)
IE1 |= WDTIE;                       // Enable WDT interrupt
P1DIR |= BIT3 + BIT4 + BIT5;
_BIC_SR(GIE);
 while(1)
#pragma vector=WDT_VECTOR
__interrupt void watchdog_timer(void)
    cycle++;
     if(cycle >= pwmred) {
         P1OUT &= ~BIT3;
     if (cycle >= 255)
         if(pwmred > 0)
             P1OUT |= BIT3;
         cycle = 0;
The interrupt is not triggering, I am checking using the debugger and it is also not acting as expection. I am using the latest version of code composer studio. Did I forget something important. I would expect the watchdog_timer method being called every 0.5 ms, but that is not working.
  • \$\begingroup\$ any link to instruction set? \$\endgroup\$ – Flood Gravemind Apr 29 '17 at 23:22
  • \$\begingroup\$ Did you tried to enable all interrupt? ( __enable_interrupt() ) \$\endgroup\$ – M.Ferru Apr 29 '17 at 23:56
Because you disabled global interrupts.
_BIC_SR(GIE);
Is Bit Clear Special register.
You want
_BIS_SR(GIE);
Bit Set special register.
Or use __enable_interrupt(); as mentioned.
It seems that you forgot to enable the interrupt in your code. You can enable all the interrupt with __enable_interrupt(); or enable specific interrupt with _BIS_SR(name_of_interrupt);
  • \$\begingroup\$ Specific interrupts cannot be enabled in the SR. \$\endgroup\$ – CL. Apr 30 '17 at 8:43
