Note: (W/L)ratio of M5 = 3 * (W/L)ratio of M7
I would like to ask if there is a preferable method for accurate current mirroring between the two schematics below. To make it clear what I would like to say, in the left schematic we have a simple current mirror and we want to provide in the load three times the current of M7 (so the purpose is the Iload = 3mA).To achieve this I will choose the W/L ratio of M5 to be three times greater than the W/L ratio of M7.
On the other hand to achieve the same purpose in the right schematic we place four identical transistors (M1,M2,M3,M4) with the same W/L ratio. So I know that the load will have again three times bigger current (3mA).Which schematic provide better accurate current mirroring?
Advantages, Disadvantages for these typologies?
I have read that the right schematic gives us better accuracy. Is it true?
Currents are only accurately mirrored IF the transistors are identically constructed (implants, gate sizes, contacts, metals, etc including the surrounding implants affecting outgrowth of the mirroring-devices implants and surrounding metal/poly that affect the electric fields), and the temperatures are identical and the I_V operating conditions are identical.
|improve this answer|||||
