On AVR ATmega devices, the USART has the capability to function in SPI mode (i.e. synchronous with no start or stop bits). The chief operational difference is that the TX line (i.e. MOSI) has a buffer, while the SPI hardware MOSI has no buffer. According to this Atmel application note (http://www.atmel.com/Images/doc2577.pdf), this buffer makes it possible to continuously transmit data. This is in contrast to the SPI hardware where SCK must be halted while a new byte is being loaded into SPDR.
With this in mind, which of the following programs to transmit 200 bytes from a buffer buf[200] would complete in the shortest amount of time? (Assume that all are configured at fosc / 2.)
Polled SPI:
for(int B = 0; B < 200; ++B)
  SPDR = buf[B]; // Load next byte into SPDR
  while(!(SPSR & (1 << SPIF))); // Wait for SPIF to be set
  (int)SPDR;  // Read SPDR to clear SPIF
Interrupt-driven SPI:
ISR(SPI_STC_vect)
  if(B < 200)
     ++B;
  else
     SPCR &= ~(1 << SPIE); // Disable SPI interrupts
  return;
Polled USART in SPI mode:
  UDR0 = buf[B]; // Load next byte into UDR
  while(!(UCSR0A & (1 << UDRE))); // Wait for UDR empty
Interrupt-driven USART in SPI mode:
ISR(USART0_UDRE_vect)
  if(B < 200)
     UDR0 = buf[B]; // Load next byte into SPDR
     ++B;
  else
     UCSR0B &= ~(1 << UDRIE); // Disable UDRE interrupt
  return;
Unless there are a lot of competing interrupts, the polling USART method would be fastest.
For fast SPI transfers (with fosc/2) the interrupt entry and exit would be too long, and the SPI methods have the gaps mentioned in the question.
