The standard NPN BJT in SOT-23 package has the following arrangement of pins:
Do you know of any transistor that has pins 1 and 2 reversed? So that 2 is the base while 1 is the emitter (Doesn't matter if NPN or PNP, i.e. Emitter or Collector). I truly can't seem to find such a device.
