I'm encounter following schematic in a product.
It gets 110VAC and provide 5V DC to the board. After many inspection I still can't understand what Q2 and R4 do in this design.
First of all after T1, Voltage down convert to 27.5 volt. If we assume D1, R3 and D2 reduce at most, Vin at Voltage Regulator will at least be 25V in no load which is very higher than LM123 Vin Absolute Maximum (Specified 20V in Datasheet)
And another mystery is, if we assume 5V at the LM123 output, Base-Emitter junction of Q2 will have 20V on it :|. So IMO either of Q2 or LM123 will explode.
So the question is where am I going wrong?
