I have coded a simple blink example for a dsPIC30F2020. I think that the schematic is correct, but I am unsure of the configuration bits.
Tools :
- MCU : dsPIC30F2020
- Programmer : PICKit 2
- IDE : MPLAB X IDE v3.60
Here is the code:
#include "xc.h" #include "libpic30.h" #include "stdio.h" #include "stdlib.h" #include "p30F2020.h" // xtal #define _XTAL_FREQ 16000000 // DSPIC30F2020 Configuration Bit Settings // 'C' source line config statements // FBS #pragma config BWRP = BWRP_OFF // Boot Segment Write Protect (Boot Segment may be written) #pragma config BSS = NO_BOOT_CODE // Boot Segment Program Flash Code Protection (No Boot Segment) // FGS #pragma config GWRP = GWRP_OFF // General Code Segment Write Protect (General Segment may be written) #pragma config GSS = GSS_OFF // General Segment Code Protection (Disabled) // FOSCSEL #pragma config FNOSC = PRIOSC // Oscillator Mode (Primary Oscillator (HS, EC)) // FOSC #pragma config POSCMD = HS // Primary Oscillator Source (HS Oscillator Mode) #pragma config OSCIOFNC = OSC2_CLKO // OSCI/OSCO Pin Function (OSCO pin has clock out function) #pragma config FRANGE = FRC_HI_RANGE // Frequency Range Select (High Range) #pragma config FCKSM = CSW_FSCM_OFF // Clock Switching and Monitor (Sw Disabled, Mon Disabled) // FWDT #pragma config WDTPS = WDTPOST_PS32768 // Watchdog Timer Postscaler (1:32,768) #pragma config FWPSA0 = WDTPRE_PR128 // WDT Prescaler (1:128) #pragma config WWDTEN = WINDIS_OFF // Watchdog Timer Window (Non-Window mode) #pragma config FWDTEN = FWDTEN_OFF // Watchdog Timer Enable (Disable) // FPOR #pragma config FPWRT = PWRT_128 // POR Timer Value (128ms) // FICD #pragma config ICS = ICS_PGD // Comm Channel Select (Use PGC/EMUC and PGD/EMUD) int main(){ _TRISD0 = 0x00; while(1){ _RD0 = 0xff; __delay32(150000000); _RD0 = 0x00; __delay32(150000000); } return 0; }
Pickit 2 screenshot :
When I connect the LED to RD0 (pin 15), the LED lights up all the time; it does not blink.
What might be wrong?
[UPDATE]
I think the __delay32()
is the problem. Any idea?
