-1
I am attempting a diy project and I am completely new to electronics so please bear with me. I found a schematic online which I want to create a pcb from. I know the very basics about pcbs and schematics in general.
The original schematic I found uses three 8-pin ICs but the way the schematic was drawn has each IC's 8 pins split up into two separate-looking parts for easy understanding.
I tried to recreate the same schematic but with each actual 8-pin IC as one solid component. This is so I can create a PCB easier (layout out etc).
Could you kindly look at both the original and my redrawn one and see if I have done it correctly and it is exactly the same circuit before I order the board? I would really appreciate it.
Original: enter image description here Re-drawn one: enter image description here
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$ – Dave Tweed May 8 '17 at 0:55
I have pointed out some of the problems in the below diagram- there may be more, I just ran out of patience and my coffee arrived:
The dot on C2 means you didn't line up the wire with the end. It will still be okay but it looks ugly. I didn't flag it but C2 and C3 do not have polarity. The symbol should be different. U1 1&2 are shorted. V- on the op-amps is wrong on all 3 (but in two different ways). The pots and the 6 connections to each pair are completely wrong. R9 is the wrong value. The output jack J3 has left and right channels swapped, and so does the input jack (not marked).
I agree with the comment that not breaking the op-amp into proper symbols as in the original makes it harder to follow. I have yelled at people for this kind of thing. That is a style issue, but it's more worrisome that you have missed a lot of details.
Consider looking at the netlist that Orcad generates (in human readable form)-- you should be able to see each individual net and verify which pin of which part is connected to each net.
    \$\begingroup\$ Wow. Thanks so much for taking the time to answer my question. This is my first ever attempt at anything electronics, so it is clear I may have bitten more than I can chew. I have so much to learn. Thanks! Hope the coffee was delicious. \$\endgroup\$ – Bruno May 7 '17 at 15:41
