I would like to use use a RTOS and OS side by side to implement a cooperative work.
The RTOS would perform time critical (real-time) task and the OS will perform the other non-critical functionalities such as user display, tcp/ip communication etc.
Can you recommend any framework or projects that is able to achieve this need ? It would be great if it is open source.
RTOS and OS would have some kind of communication mechanism. (mail box or shared memory)
If needed, the RTOS could run on a specific core and the OS on another core. (with dual core CPU)
A possible configuration could be:
Zephyr (RTOS) and Linux (OS).
FreeRTOS (RTOS) and Linux (OS).
As of now, I found this information: http://www.evidence.eu.com/embedded-linux-osekvdx-erika-enterprise-dual-core-automotive-cpu-without-hypervisor.html
Is there anything else available ?
