Very simple example I am stuck with. I want design written in Verilog to return a year defined in source as 16-bit format to the outer world using two bytes.
`define MY_YEAR 16'd2017
then I need to somehow split this constant into two bytes to perform something like this
wire [7:0] w_year_byte = w_current_byte ? (`MY_YEAR >> 8) : (`MY_YEAR & 8'hff);
For me above expressions with MY_YEAR are not correct as their result is still 16-bit. And this statement does not compile at all...
I know how to do it with vectors, but have never done it before for constants; saw several answers for similar questions on the internet, but still unclear how to make things properly. May appear that my approach is totally wrong, will be extremely glad for educating me.
Update: my Verilog source is relatively big, and the main idea was to have this year definition at the very beginning of the source file, on the first line, because it will be changed frequently and I would not need to go down to find the value to change.
Reviewing Tom Carpenter's answer I realized I was making stupid mistake trying to declare parameter, local parameter or wire outside of the module (at the top of the source, before module declaration), so I follow his suggestion to have
on the first line of the source, and then somewhere after module declaration having
wire [15:0] c_MY_YEAR = `MY_YEAR;
and then using c_MY_YEAR[7:0]
and c_MY_YEAR[15:8]
as usual. Thanks Tom!
