Stupid question fellow Stack users...
Can I use Google's ADK on the original Arduino Mega 2560? From what I can tell, the main difference between the Mega2560 and the Arduino ADK is the addition of the USB host port on the board. I haven't played with ADK yet and cannot seem to find any direct answers via the Tubes.
Your help is greatly appreciated!
You will need the arduino ADK shield
http://www.emartee.com/product/42089/Arduino%20ADK%20Shield%20For%20Android
This works with all kinds of arduinoes :)
  • \$\begingroup\$ Is this shield required just for programming or to run the developed program later? Reason i ask is that I am wanting to build a project using adk, arduino and ethernet shield to provide web server/android app integration over internet. Guess I am confused as to why the USB host shield is so important. \$\endgroup\$ – ThaKidd KG5ORD Apr 21 '12 at 3:42
    \$\begingroup\$ You need the USB host shield to be able to connect your arduino to the android device and communicate with it. \$\endgroup\$ – Shungun Apr 21 '12 at 4:07
  • \$\begingroup\$ @ThaKidd, you plug your Android device into the USB host port. The host port is not meant to be plugged into a PC. The android device switches to a USB slave device while your accessory hardware becomes a USB host. This is the way they have chosen to do things with Android ADK. \$\endgroup\$ – Jon L Apr 21 '12 at 7:51
