-3
My STM32F051C8T6 is restarting spontaneously every about 400ms. NRST pin is decoupled with 100nF capacitor. I think that it isn't hardware reset - even with 220R pull-up it is still restarting. Watchdog is disabled. Microcontroler can be programmed. I'm programming it with ST-Link Utility using only SWDIO and SWCLK without RESET. What can cause this problem?
The code:
  * File Name          : main.c
  * Description        : Main program body
  * COPYRIGHT(c) 2017 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f0xx_hal.h"
#include "gpio.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  /* USER CODE BEGIN 2 */
  HAL_GPIO_WritePin(GPIOB,GPIO_PIN_6, GPIO_PIN_SET);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
UPDATE:
#include "stm32f0xx.h"
int main(void)
    RCC->AHBENR |= RCC_AHBENR_GPIOBEN;     // Enable clock for Port B
    GPIOB->MODER |= GPIO_MODER_MODER6_0;   // Output
    GPIOB->BSRR = (1<<6);                  // Turning LED on
    for(;;);
Here is updated, simpler code. It is still self-reseting but it is one difference: when I program target with first HAL code LED is turning off for shorter time than with code written on registers. I'm afraid that microcontroller is damaged physically.
UPDATE 2
I removed old microcontroller and soldered new one. After few hours, situation repeated. Here is solution:
  1. Open ST-Link Utility.
  2. Target -> Option Bytes -> Flash sectors protection -> Unselect All.
  3. Target -> Option Bytes -> User configuration option byte -> check "WDG_SW" option.
  4. Full chip erase.
    \$\begingroup\$ Maybe your code ? \$\endgroup\$ – Eugene Sh. May 9 '17 at 14:27
    \$\begingroup\$ I'm voting to close this question because you haven't provided any source code or schematic diagram. \$\endgroup\$ – m.Alin May 9 '17 at 14:30
    \$\begingroup\$ What is "clean" code? \$\endgroup\$ – Eugene Sh. May 9 '17 at 14:45
    \$\begingroup\$ Show your "clean" code. \$\endgroup\$ – Eugene Sh. May 9 '17 at 14:47
    \$\begingroup\$ do you have a watch dog timer running? \$\endgroup\$ – old_timer May 9 '17 at 18:53
To know why the chip resets, you should check the reset flags on boot.
6.4.10 Control/status register (RCC_CSR) in the "reference manual".
The other thing you'd want to know when it happens is an Hardfault. Although by default this would cause a hang or a watchdog reset.
Look up information about the hardfault in the "programming manual".
Depending on you debugger, you might also want to enable the VectorCatch during the initialization script of the debug session. Keil example. Vectorcatch triggers a breakpoint on fault handler entry.
Manuals.
  • \$\begingroup\$ Do I understand correctly that I should check which flag is on in RCC_CSR register when reset occurs? Thanks to this I can tell source of this behaviour? I'm trying to debugg in STM32 eclipse workbench but I can't read register status. \$\endgroup\$ – Piotr May 9 '17 at 19:37
