What is the difference between a D flip flop and an SR flip flop?
closed as too broad by Eugene Sh., Trevor_G, Enric Blanco, Wesley Lee, Dmitry Grigoryev May 11 '17 at 8:32
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Sounds very home-workish... \$\endgroup\$ – Eugene Sh. May 9 '17 at 17:14
  • \$\begingroup\$ I'm just trying to understand the flip flops, pretty new to this. \$\endgroup\$ – Eugen Valentin May 9 '17 at 17:15
  • \$\begingroup\$ Neither one has an inherent problem. They do two different things. \$\endgroup\$ – Spehro Pefhany May 9 '17 at 17:15
  • \$\begingroup\$ @SpehroPefhany Well.. one of the input combinations of SR is problematic.. But that's what JK is solving. \$\endgroup\$ – Eugene Sh. May 9 '17 at 17:16
  • \$\begingroup\$ OK, after the edit the question is becoming off-topic (or too broad? VTC, anyway.). This information is easily available around and you have to do your own research... Oh wait.. @laptop2d it was your edit. I think it's quite different from the OPs intent. \$\endgroup\$ – Eugene Sh. May 9 '17 at 17:21
A D-flip flop basically stores the value for one clock cycle (and functions like a buffer, a chip enable pin will let you store for multiple clock cycles).
An SR flip flop is like a light switch. Set turns it 'on' and reset turns it 'off'
