I am working on converting an old ATX PSU to a DIY lab bench power supply. Everything is going well, but I can't seem to find out the correct dummy resistor load values.
The 3.3v rail has 22A and the 5v rail has 21A, and usually the dummy load should be on the rail with most power. However, I read that it's very rarely it's put on the 3.3v rail, so I will put it on the 5v rail.
But I need some help to find the correct value to put on the dummy load. And should the resistance be in parallel or series?
