I would love to follow the most common pinout (I design connector and receptable, but you never know).
I find conflicting sources:
-RJ45 connector exact same pinout number by number: Folloing RJ45 plug pinout literally 1 is 1, 2 is 2, .... 8 is 8
-A big cable producing brand Turck seems to have another "standard", I did see this at one of our clients: enter image description here
Or, is there no (de facto) standard?
UPDATE: we are using the Turck standard on all our cables now. This seems the de facto standard.
Mouser M12 Vs RJ45
On page 2 of this info sheet from Phoenix Contact, it says "There is still no agreed standard on wiring an eight-pin variant for Industrial Ethernet."
Hope that helps
    \$\begingroup\$ thanks. FYI I got an answer back from Turck. They labeled their own pinout as "CORRECT" and the pin-by-pin with RJ45 connectors as "INCORRECT" (but I guess, that's their view :) ) \$\endgroup\$
    – lode
    May 15, 2017 at 21:42
  • \$\begingroup\$ Here's also an HTML version of the linked article: iebmedia.com/… \$\endgroup\$ Jun 4, 2020 at 14:21
Below a table I made of the most widely used standard I have seen. Hope this helps someone out. This does match the "Turck" standard.
    \$\begingroup\$ This confirms the "Turck" layout from in the question. I have indeed not seen other layouts since. \$\endgroup\$
    – lode
    Dec 8, 2022 at 22:38
OR this.
Source: https://bilder.tragant.de/produkte/orig/5c51a102e4ef30.77076833.jpg
I use M12 A-code. But I decided to use the same standard as X-code. We now always order cables from China.
Source: https://bilder.tragant.de/produkte/orig/5d7f5208916659.72117111.jpg
