I've been given a question like Draw the spectrum of FM signal with modulation index beta = 0, 1 ,2,2.5. I know that it is something related to finding bessels values of the given beta but I don't know what to do after finding the values.My teacher simply posted a solution without any explanation.I've kept the image of solution please tell me how to get those answers.
Here is the solution
closed as unclear what you're asking by Enric Blanco, laptop2d, Autistic, PeterJ, Dmitry Grigoryev May 17 '17 at 15:39
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Look in any communications textbook. The section describing FM will give the equation for the spectrum in terms of Bessel Functions and the modulation index. Then you can use a table of Bessel Functions to find the levels of each component. \$\endgroup\$ – Barry May 14 '17 at 18:46
    \$\begingroup\$ I'm voting to close this question as off-topic because it looks like Homework. \$\endgroup\$ – Autistic May 17 '17 at 10:28
  • \$\begingroup\$ @Autistic I'm preparing for final exam and I asked a doubt. On what basis are you saying this as homework question ? I even uploaded the answer and just asked an explanation for it. Whats wrong in this ? Being a senior with 5k reputation can't you even understand the difference between a homework question and a doubt clarification ? \$\endgroup\$ – bharath May 17 '17 at 10:33
From page 8-5 of these class notes from UMD (using Hz instead of radians/sec), the spectrum of an FM tone can be written as
$$s(t) = A_c \sum_{n=-\infty}^{\infty}J_n(\beta)\cos[2\pi(f_c+nf_m)t]$$
where \$A_c\$ is the carrier amplitude, \$f_c\$ is the carrier frequency in Hz, and \$f_m\$ is the frequency of the modulating tone in Hz. Moving this to the frequency domain gives us:
$$S(f) = \frac {A_c} 2 \sum_{n=-\infty}^{\infty} J_n(\beta) [\delta(f - (f_c + n f_m) + \delta(f + (f_c + n f_m)]$$
We can plot this FM spectrum as delta functions with "height" (more accurately, area) \$\frac {A_c} 2 J_n(\beta)\$. Thus, the Bessel function values form the basis of the coefficients of the frequency components.
If you're doing power calculations don't forget to include the negative frequencies as well!
