I'm working on a circuit with a non-inverting amp and I would like to switch between two reference voltages, both with low output impedance.
So in effect i want something like this:
One thing: R1 is done using LM385 low power reference voltage, so voltage between anode and katode of D1 is 1.2V. Output impedance of U1 is about 300 ohms.
I stumbled upon a thing called analog multiplexer and I think that it would suit this purpose quite OK. I would like to build it using basic components instead of buying IC. I thought about using JFETs, but would it make sense for such small voltages?
Please help!:)
  • \$\begingroup\$ Please post the schematic of the circuit you're proposing to use to implement an analog multiplexer using JFETs. \$\endgroup\$
    – The Photon
    Commented May 14, 2017 at 15:07
  • \$\begingroup\$ In principle, yes you can. Are you as far along as having a circuit yet? If so, please edit your question and add the circuit to it. Or are you right at the start, just wondering if it's even a good idea? Thanks. \$\endgroup\$
    – TonyM
    Commented May 14, 2017 at 15:23
  • \$\begingroup\$ Why use two references when apparently one would suffice with a pot divider? \$\endgroup\$
    Commented May 14, 2017 at 15:52
  • \$\begingroup\$ @Andyaka Alright, I added more detailed schematic:) It is a part of a more complex circuit. What I need right now is just to make this mux, preferably using basic ocmponents such as JFETs:) I'm pretty much sure that it is a good idea. Is it possible? \$\endgroup\$
    – Em Ka
    Commented May 14, 2017 at 15:55
  • \$\begingroup\$ I think the best idea is use a chip. \$\endgroup\$
    Commented May 14, 2017 at 16:03
