I'm about to do cabling in a server rack that consists of two switches and forty 1U servers. Since every server has three ethernet cables attached we'll have around 120 cables in a single rack.
Is putting unshielded RJ45 connector on a shielded Cat6 ethernet cable a good idea? Since the RJ45 connectors are very close to the endpoints, does it really matter (EMI-wise)?
How important is grounding of that cable? Should I go extra mile and put RJ45 connectors with metal jackets that connect to the external metal shielding of Cat6 cable?
Thank you in advance.
