This is my code:
#include "stm32f10x.h"
#include "core_cm3.h"
#include "custom.h"
//#include "LCD-HD44780.h"
//int i;
int main(void)
    RCC->APB2ENR |= BIT3;
    GPIOB->CRH   |= BIT0 || BIT1;
    GPIOB->CRH   &= ~BIT2 && ~BIT3;
    GPIOB->BSRR  |= BIT8;
    GPIOB->CRH   |= BIT4 || BIT5;
    GPIOB->CRH   &= ~BIT6 && ~BIT7;
    GPIOB->BSRR  |= BIT9;
    while (1)
custom.h file:
#include <stdint.h>
#define BIT0  (uint32_t)0x1
#define BIT1  (uint32_t)0x2
#define BIT2  (uint32_t)0x4
#define BIT3  (uint32_t)0x8
#define BIT4  (uint32_t)0x10
#define BIT5  (uint32_t)0x20
#define BIT6  (uint32_t)0x40
#define BIT7  (uint32_t)0x80
#define BIT8  (uint32_t)0x100
#define BIT9  (uint32_t)0x200
#define BIT10 (uint32_t)0x400
#define BIT11 (uint32_t)0x800
#define BIT12 (uint32_t)0x1000
#define BIT13 (uint32_t)0x2000
#define BIT14 (uint32_t)0x4000
#define BIT15 (uint32_t)0x8000
#define BIT16 (uint32_t)0x10000
#define BIT17 (uint32_t)0x20000
#define BIT18 (uint32_t)0x40000
#define BIT19 (uint32_t)0x80000
#define BIT20 (uint32_t)0x100000
#define BIT21 (uint32_t)0x200000
#define BIT22 (uint32_t)0x400000
#define BIT23 (uint32_t)0x800000
#define BIT24 (uint32_t)0x1000000
#define BIT25 (uint32_t)0x2000000
#define BIT26 (uint32_t)0x4000000
#define BIT27 (uint32_t)0x8000000
#define BIT28 (uint32_t)0x10000000
#define BIT29 (uint32_t)0x20000000
#define BIT30 (uint32_t)0x40000000
#define BIT31 (uint32_t)0x80000000
LED on Pin 8 turns on But in Pin 9 does not!. and This all of code I wrote. I cant find out where is problem.
| improve this question | | | | |
  • \$\begingroup\$ Where you set GPIOB->CRH you have "&&" in two of the lines. Change them to just "&". The "&&" operation is the logical AND, the "&" is the bitwise AND. \$\endgroup\$ – Finbarr May 16 '17 at 11:03
You have two lines of code where you set GPIOB->CRH:
The && operator is the logical AND, which returns true or false. What you need to use here is the & operator, which is the bitwise AND.
The same applies to the logical OR operator || and the bitwise OR | in the other lines of code.
| improve this answer | | | | |
    \$\begingroup\$ Same goes for || it should be |. \$\endgroup\$ – Bence Kaulics May 16 '17 at 16:13
