How to calculate the required storage capacity of a data logger given the measurement time sampling rate and resolution?
I want to log two voltages at 1Hz rate for 3 months continuously and looking for a cheap data logger for this purpose. But most of them have not enough storage.
    \$\begingroup\$ Data_per_sample x Samples_per_second x seconds_in_total \$\endgroup\$ – Eugene Sh. May 16 '17 at 14:36
  • \$\begingroup\$ It would make more sense to monitor and save changes and disturbances \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 16 '17 at 14:51
  • \$\begingroup\$ @TonyStewart.EEsince'75 It is a bit dangerous. Is some portion of the data is lost - everything (after that point) is lost... \$\endgroup\$ – Eugene Sh. May 16 '17 at 14:52
  • \$\begingroup\$ absolute data can be included less frequently say once an hour or day to permit.. DATAQ makes RMS loggers \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 16 '17 at 14:57
  • \$\begingroup\$ But if you are concerned about PC PSU loss of power, then dropouts > 1 cycle must be detected. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 16 '17 at 15:01
This is really basic math, although you left out one important parameter, which is the sample size.
Let's say each sample is 16 bits for sake of example. At 1 Hz rate, that means you need 16 bits, or two bytes, for every second of running time. Your running time is 3 months. Do the math:
  (3 months)(30 days/month)(24 hours/day)(3600 s/hour)(2 bytes/s)(2 channels) = 31 MBytes
Yes, it really is that simple.
|improve this answer|||||
Isn't this just basic maths?
1 sample per second * 60 seconds * 60 minutes * 24 hours * 30 days * 3 months = 7,776,000 points.
Assuming a 16 bit ADC that is then 2 channels * 2 bytes * 7,776,000 = 31.104 MBytes of data.
Even allowing for basic checksums and data formatting any data logger with the ability to log to an SD card should do the job.
    \$\begingroup\$ Not even maths...arithmetic. Upvoted. \$\endgroup\$ – TonyM May 16 '17 at 14:42
    \$\begingroup\$ Actually, it's basic math, not maths, but still otherwise correct. "Math" is a subject of study, so the plural form doesn't make any sense. You don't say "physicses", "geologies", or "arithmetics" either. \$\endgroup\$ – Olin Lathrop May 16 '17 at 14:45
    \$\begingroup\$ @OlinLathrop ... grammarist.com/spelling/math-maths \$\endgroup\$ – Tut May 16 '17 at 14:52
    \$\begingroup\$ don't forget the timestamp... \$\endgroup\$ – dandavis May 16 '17 at 16:45
