I'm trying to Bild my own boombox with an 2*50W Bluetooth amplifier and 10 18650 cells with 3,4Ah each. I habe bought a tp4056 charging board. The question is if i use 10 betteries connected in parallel and connect the minus and plus to my tp4056 board if it would be able to charge the safely. Or do I need a balance charger?
\$\begingroup\$ No need for balancing parallel batteries. \$\endgroup\$ – JimmyB May 17 '17 at 9:42
You theoretically don't need anything, but there are drawbacks:
The charging will be 10 times slower compared to a single cell charged from a TP4056
A damaged cell will cause the others in the pack to drain and you'll never be able to charge or maintain the pack at full capacity.
A damaged cell will also cause even more slower charging.
So if you make sure all cells are good, you should be fine for a while.
\$\begingroup\$ Short circuit current can become dangerously (fire) high - fuse each cell with a thin connecting wire / track \$\endgroup\$ – Henry Crun Mar 16 '18 at 22:50
\$\begingroup\$ For standard cells, you can use a 3.15A fuse for each cell. That makes sure no accidents happen. A cell can deliver up to 2A safely, so at above 3 means there's a problem and that's where the fuse comes in. adelaida.ro/images/thumbnails/31/120/… \$\endgroup\$ – Overmind Mar 22 '18 at 20:38
\$\begingroup\$ is there other charging modules like TP4056 for charging multiple batteries in parallel? \$\endgroup\$ – kit Nov 5 '18 at 5:56
\$\begingroup\$ I build myself a 12-slot charger using TP4056s. I can charge 12 cells if the PSU is good quality on the 5V rail. xaeus.wordpress.com/2018/02/14/… \$\endgroup\$ – Overmind Nov 7 '18 at 12:59
