I am using an STM32L0 series MCU. I configured my MCU to wake up from Stop Mode using an EXTI line (EXTI0 at PORTA0) during falling edge. At the beginning, it wasn't going to the Stop Mode after I called _WFE(). After tried several things I called _WFE() twice, one after another and that did the trick. Although this solved my problem I was wondering if anyone can shed some light. Maybe I am missing something.
Here is my code:
void HW_WakeupPinInit(void)
   GPIO_InitTypeDef gpioInitStruct = {0};
   gpioInitStruct.Mode      = GPIO_MODE_INPUT;
   gpioInitStruct.Pull      = GPIO_PULLDOWN;
   gpioInitStruct.Speed = GPIO_SPEED_HIGH;
   HW_GPIO_Init( WAKEUP_PORT, WAKEUP_PIN, &gpioInitStruct );
   LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SYSCFG);
   LL_SYSCFG_SetEXTISource(LL_SYSCFG_EXTI_PORTA, LL_SYSCFG_EXTI_LINE0);
   LL_EXTI_InitTypeDef EXTIinitStruct = {0};
   EXTIinitStruct.Line_0_31 = LL_EXTI_LINE_0;
   EXTIinitStruct.LineCommand = ENABLE;
   EXTIinitStruct.Mode = LL_EXTI_MODE_EVENT;
   EXTIinitStruct.Trigger = LL_EXTI_TRIGGER_FALLING;
   LL_EXTI_Init(&EXTIinitStruct);
void HW_EnterStopMode(void)
   uint32_t tmpreg = 0U;
   BACKUP_PRIMASK();
   DISABLE_IRQ();
   HW_IoDeInit();
   /*clear wake up flag*/
   LL_PWR_ClearFlag_WU();
   RESTORE_PRIMASK();
   tmpreg = PWR->CR;
   /* Clear PDDS and LPSDSR bits */
   CLEAR_BIT(tmpreg, (PWR_CR_PDDS | PWR_CR_LPSDSR));
   Set LPSDSR bit according to PWR_Regulator value */
   SET_BIT(tmpreg, LL_PWR_REGU_LPMODES_LOW_POWER);
   /* Store the new value */
   PWR->CR = tmpreg;
   LL_LPM_EnableDeepSleep();
   __WFE();
   __WFE();  // <------- Calling __WFE() second time works.
Thanks in advance.
I have solved your issue by following method.
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin : PA10 */
GPIO_InitStruct.Pin = GPIO_PIN_10;
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
EXTIinitStruct.Line_0_31 = LL_EXTI_LINE_10;
EXTIinitStruct.Mode = LL_EXTI_MODE_IT_EVENT;
EXTIinitStruct.Trigger = LL_EXTI_TRIGGER_RISING_FALLING;
HAL_PWR_EnterSTOPMode(PWR_MAINREGULATOR_ON,PWR_SLEEPENTRY_WFE);
LL_EXTI_DeInit();
  • 6
    \$\begingroup\$ It would be better if you said (as a description) what the cause of the failure was. \$\endgroup\$ – Sean Houlihane Feb 8 '18 at 14:15
  • \$\begingroup\$ Why rising edge on the GPIO and rising/falling on EXTI? \$\endgroup\$ – ColinH Jan 4 '19 at 22:08
  • \$\begingroup\$ Interesting enough implementation of HAL_PWR_EnterSTOPMode actually calls _WFE() twice (which can be seen here: line899). So I guess that's how it should be, although the datasheet doesn't say anything! I will mark this as solved. \$\endgroup\$ – Fahad Jan 6 '19 at 22:10
