I am asked to determine what the unknown component (Zs) is. I know that the maximum power theorem states (after derivation) that the
$$P_{\text{load}}=\frac{V_{\text{th}^2}}{4R_{\text{th}}}$$
I would be able to find the thevenin voltage and resistance if there were all resistors in the circuit but don't know what to do in this case. Is there a way to determine what the unknown impedance is? I know that a capacitor has always a negative impedance and a conductor = positive impedance but I don't know about the resistor.
How do I find the determine the component of Zs?enter image description here
  • \$\begingroup\$ Considering it is a question with "RF generator" in it, it could be that they want you to solve this using transmission line/reflection coefficient and such. Consider looking at impedance matching to get started \$\endgroup\$
    – Joren Vaes
    May 18, 2017 at 9:37
    \$\begingroup\$ Hint: For max power transfer, \$Z_S=Z_L^*\$. \$\endgroup\$ May 18, 2017 at 10:02
  • \$\begingroup\$ So shall I find the impedance of the Rl ( ZL ) and the complex conjugate of that would be the impedance Zs? \$\endgroup\$
    – Michael
    May 18, 2017 at 10:10
  • \$\begingroup\$ The load impedance \$Z_L\$ is the parallel combination of \$L_L\$ and \$R_L\$. So having calculated that you can indeed take the complex conjugate to get \$Z_S\$. From there you can work out what series components you would need to achieve it. \$\endgroup\$ May 18, 2017 at 10:30
  • \$\begingroup\$ great! I calculated the parallel load impedance ZL as = 40+20j therefore Zs = 40-20j How can I determine what components to use \$\endgroup\$
    – Michael
    May 18, 2017 at 10:46
No doubt you are currently studying series and parallel equivalent circuits based on the nature of the problem.
To start off, observe that the load shown produces maximum power from the generator. This means that it satisfies the maximum power transfer theorem. More specifically it also makes it clear that the load is a conjugate match. This means that the reactance in the load is equal and opposite to the reactance in the source generator and that the resistive component of the load is equal to the resistive component of the source generator.
To convert the parallel load shown in the diagram to a series load, you must first calculate the reactance of the inductor at the frequency of the generator using the standard inductive reactance formula. Since this is an inductive reactance, the sign of the reactance will be positive.
You can now use the standard parallel to series conversion formulas to convert the load to an equivalent series circuit. First compute the series resistance using the formula
Rs = (Rp*Xp2)/(Rp2+Xp2)
You then convert the parallel reactance to its equivalent series reactance using the formula
Xs = (Rp2*Xp)/(Rp2+Xp2)
Pay attention to the sign of Xs. If it is negative, then it is capacitive reactance. If it is positive, then it is inductive reactance. Knowing that, use the standard reactance formulas to convert the result to the correct inductance or capacitance at the frequency of the generator.
Note at this point that your series reactance in the load is exactly the opposite reactance of the series reactance in the generator, thereby meeting the conjugate match condition. This is also helpful since all circuit elements are in series and of known values, you can calculate the current through the elements and as a result the power dissipated by the series load resistor in order to answer the second part of the problem.
You can now also draw a schematic of the internal parts of the signal generator given what you know about the series load and the problem description since the unknown series reactance in the supply is the equal value but opposite sign of the reactance in the series load.
