I want to count pulses through sound-card of a PC or a smartphone's audio port. Two different pulses will originate from two LM331 and I can scale them to 1V or any amplitude.
I want to feed these pulses to the audio port of a sound card's channels. Then the rest is to software to count the pulses.
So far I plan to use this analog interface between the pulses and the audio jack and sound-card:
Do you think the topology is correct? How can I improve this interface for the noise? I am only interested to count pulses not to view any other signal.
Edit: R1 R2 sets the voltage at X.
  • \$\begingroup\$ This question would be much better if you explained why you chose to design it like this. \$\endgroup\$ May 18, 2017 at 10:17
  • \$\begingroup\$ And the frequency of these pulses is ??? \$\endgroup\$ May 18, 2017 at 11:00
  • \$\begingroup\$ @JImDearden Frequency of the pulses can be set from 100Hz upto 10kHz or more by LM331. I can adjust the freq. I mean. So lets call it "f" if you have an idea. \$\endgroup\$
    – user16307
    May 18, 2017 at 11:03
  • \$\begingroup\$ The reason I asked was if the frequency is in the audio band (as you've indicated) - no problem, if it was a very low frequency such as 0.1Hz then you'll need a different technique to get the pulse into an audio card. \$\endgroup\$ May 18, 2017 at 11:06
  • \$\begingroup\$ @JImDearden How about if it were a smart phone audio jack instead of a soundcard? Can I use the same interface? \$\endgroup\$
    – user16307
    May 18, 2017 at 11:08
Check what the input impedance of the sound card is. It may be that the signal will get significantly attenuated by the 22 kΩ in series. A common input impedance for "line" inputs is 600 Ω, for example.
I'd start with 1 kΩ in series followed by just two back to back diodes to ground. ±700 mV is still a substantial signal for line level audio, and totally overwhelming for a microphone input.
If you only have a microphone input, then add another resistor divider after the clipping diodes. ±10 mV is a strong microphone signal.
  • \$\begingroup\$ Should I match the series resistor to the input impedance of the soundcard? Is that something to do with max power transfer? \$\endgroup\$
    – user16307
    May 18, 2017 at 11:07
  • \$\begingroup\$ I edited my question regarding your answer. Please see my edit. Was that you suggested? And the voltage at X should not exceed 10mV(pulse amplitude in my case) right?. \$\endgroup\$
    – user16307
    May 18, 2017 at 11:44
  • \$\begingroup\$ @user: The diodes should be parallel, not series. \$\endgroup\$ May 18, 2017 at 11:48
  • \$\begingroup\$ I see thanks, I changed that. Hopefully makes sense now. \$\endgroup\$
    – user16307
    May 18, 2017 at 11:52
