I am building a step down converter using LTC3892. It will have 12V output sourcing 50A in each of two interleaved phases.
Problem is that LTC3892 has fixed current limit value at 75mV. This means that for 50A current limit, I would need a current sense resistor of 1.5mOhm which is a bit odd value.
I wonder whether I could use a 2mOhm resistor and then use a resistor divider to reduce the signal voltage from 100mV to 75mV? Has anyone had any experience with such method?
