I am working on converting an old ATX PSU to a lab bench power supply, and the guide I follow is putting a 5 ohm 10 watt dummy load resistor on the 5 V supply line. I don't have resistors of this value right now, can I instead put two 10 ohm 5 watt resistor instead? Or do I need a dummy load resistor at all?
6
Yes, that would be fine.
The goal is to draw 1A from the 5V bus as a "dummy load". Each of your 10Ω resistors will draw 0.5A, dissipating 2.5W in the process. The two of them in parallel constitute the desired load.
Yes. Putting the two resistors in parallel will share the power evenly between the two, as long as they're both the same resistance.
