This is a switching circuit used for a switched reluctance motor. In this circuit there is a 47μF capacitor on the right side. What is the capacitors function in this circuit?
    \$\begingroup\$ I suspect a 47u cap would do anything to any motor larger than a clock. More likely it's used to filter out the interference generated by the sparks of the brush so that it won't contaminate the 12V supply. \$\endgroup\$ Commented Aug 2, 2017 at 17:56
The 47-uF capacitor is not used to supply the inrush current, which would be needed to start the motor: it's value is too low to do the job (the IGBT handles 7A, so the motor will be quite powerful).
It is likely used as a noise suppressor.
This capacitor is used to keep the 12V supply 'stiff' -- i.e. reduces voltage dips when the motor draws current -- to prevent fluctuations in torque/speed under load. Put this cap as close to your motor as possible, or at least the connector for the motor on the PCB.
This capacitor is used to keep the 12V supply stable as possible.
According to the equation P=VI, when the motor draws a high current, the voltage across the motor drops, when the voltage drops, your motor speed reduces. Therefore if you have a capacitor in parallel to the motor, in times of voltage drops, your capacitor provides that necessary current to the motor so that your motor voltage remains stable, thus keeping a constant speed.
