I have a trimpot code(502) that after many searches I cant find the correct way to connect it the way I want and of course if it can be done.
As usual all potentiometers and trimpots as searched around the net are using the classic way of connection from the left leg until the middle rotation is 100 to 0 and from middle leg to right leg 0 to 100 as if we say it was a volume value the 0 and 100
So whatIi would like to know is how to connect my trimpot the way that from the left leg until the right leg rotation it gives me 0 - 100 or the opposite without the middle goes to 0 or even changes the value. I want my full left rotation to have the 0 or 100 and the full right rotation to have the other full or 0 value (like a volume knob)
Until now nowhere exists an answer or I am not searching enough.
Is there anyone who knows how to make the connections so it will work as I want or is not even possible and it needs something specific ?
  • \$\begingroup\$ I'm not too clear on what you mean. Does connecting the wiper to one of the two end terminals work? \$\endgroup\$
    – Hearth
    Commented May 21, 2017 at 16:41
  • \$\begingroup\$ @Felthry yes all ways working fine, i am just searching for the way to connect the 2 L-R legs and the Wiper so i can get the result i need \$\endgroup\$
    – Nocs
    Commented May 21, 2017 at 16:43
  • \$\begingroup\$ No, I mean, does that give you the result you want? \$\endgroup\$
    – Hearth
    Commented May 21, 2017 at 16:44
  • \$\begingroup\$ @Felthry what is so hard to understand in my question ? Assume middle is the wiper leg ... \$\endgroup\$
    – Nocs
    Commented May 21, 2017 at 16:45
    \$\begingroup\$ Your phrasing is very unclear. What do you mean by "left leg until the right leg rotation"? What do you mean "without the middle goes to 0 or changes the value"? \$\endgroup\$
    – Hearth
    Commented May 21, 2017 at 16:47
The usual way to connect a potentiometer as a volume control is:
That will make the output vary from 0% to 100% as you turn the knob from fully counter-clockwise to fully clockwise. (the Left and Right terminals may be swapped, depending on how you look at the pot.)
If you want to use the pot as a simple two-terminal variable resistor, do this:
  • \$\begingroup\$ Thanks peter for the effort and the schematic, i do connect them like the first one but it doesnt give me a full 0 - 100 on full rotation, instead it gives again 0 - 100 untill the middle :/ i tested 2 different 3 pin trimmers, i also connected both positive and negative from input in left and right and outputed from middle which i had a bad luck burning one trimmer and also until it burned a bit the 0 - 100 wasnt correct also as full rotation. \$\endgroup\$
    – Nocs
    Commented May 21, 2017 at 18:29
  • \$\begingroup\$ Can you edit your post to include a photo or manufacturer/part number of your potentiometer, and a schematic showing your connections? (hit Control-M to open the schematic editor while editing your question.) Any pot I've used will give 0 - 100% over the full rotation using the volume control circuit I showed. \$\endgroup\$ Commented May 21, 2017 at 18:54
  • \$\begingroup\$ An "audio taper" pot resistance will vary logrithmically as you turn the knob, while a linear pot will vary linearly (50% value at half rotation) - perhaps you have an audio taper or other non-linear pot? \$\endgroup\$ Commented May 21, 2017 at 18:57
  • \$\begingroup\$ My trimpot is similar to this one dipmicro.com/?datasheet=RM065.pdf \$\endgroup\$
    – Nocs
    Commented May 21, 2017 at 19:42
  • \$\begingroup\$ You are correct as to multimeter that i now doublechecked. As to the load that i use an led a small dc motor or something else it doesnt have the same way of 0 - 100 it falls 0 to middle allready \$\endgroup\$
    – Nocs
    Commented May 21, 2017 at 19:53
