I want identify a VCC pin in JTAG header on PCB use digital multimeter. The multimeter is entry-level model without continuity test mode, only Resistance mode and Diode test mode. The VCC voltage is 3.3V, but the other JTAG pins (except GND) also have the same voltage too, as it is digital logic circuit. Should I check continuity between supposedly VCC pin and other known VCC power point on the board in the Resistance mode? When checking continuity between two VCC pins, should be board powered on or off?
1\$\begingroup\$ If it's the standard JTAG port with the standard header, why measure when you can just look it up? \$\endgroup\$– Matt YoungMay 21, 2017 at 19:17
\$\begingroup\$ No, its non-standard JTAG header and all pads are not marked. \$\endgroup\$– fxgreenMay 21, 2017 at 19:22
Turn the board on, turn the DMM to measure DC voltage up to 20V (or auto range), put your black probe to a ground pad an look for some capacitors - electrolytic, tantalum or even SMD ceramics which look thicker then others. Put your red probe on capacitor's (+) pin/pad and check if this is the desired voltage (3.3V). Then if you are looking for a more convenient to use pad you can turn off the device. Test with the multimeter if the voltage is fallen enough (below 0.5V), switch the DMM to measure diode, put one of the probes on the pad you already know is VCC from previous measurement an search for a pad on which if you put the other probe the DMM will say "0.000" or similar.
About measuring continuity and diodes. Actually these tests are quite similar, even on some models both test are combined. The difference is that continuity test show on the display something close to the ohmic resistance of the connection, while diode test shows mV of PN junction.
Most commercial DMMs inject curent and measure resulting voltage. That's because it's simpler and much more accurate to inject a predefined constant current and to measure low voltage than measuring very small current, resulting form a constant voltage. The current depending on DMM's model is between 0.1mA and 2mA and is very unlikely to burn anything. There are 3 main reasons you have to make a continuity measure on a turned off equipment
- for a HV equipment it can burn your DMM, not the equipment itself;
- for a sensitive LV equipment multimeter's current can change some input's state and lead to undesired response of the system;
- when you place your probes over a certain voltage (say 1V or more) in one direction your DMM will state "connection", on other direction it will say "disconnected" and none of them would be true :)
The board should definitely be off when checking continuity. (The DMM injects a voltage and measures the resulting current, which may break things if the board is powered up.)
Assuming the JTAG pinout is non-standard (there are many "standard" JTAG pinouts, check thoroughly before reaching this conclusion), and you know where all the rails on the board are, then yes, you can check for continuity between the rails and the VCC pin (with the board powered off). However, with a non-standard pinout, what are you going to do once you find VCC? How will you determine the other JTAG signals?
\$\begingroup\$ There are only 8 pins. GND pin is known. Then there remains 6 pins that need to be identified, from which five should be TDI, TDO, TCK, TMS, TRST(optional). Will try use logic and exclusion method. My DMM have no dedicated continuity mode, can I perform a continuity test use Resistance mode?(with the lowest Ω setting) \$\endgroup\$– fxgreenMay 21, 2017 at 19:56
\$\begingroup\$ Yes, resistance measurements will work fine. \$\endgroup\$ May 21, 2017 at 20:08
